Home > Maintenance & Mods (L322) > How do I Unplug this socket
Cavalier
2011 Range Rover Vogue 4.4 V8 Orkney Grey
I am having to change the high break light on my car, but cannot get the plug out of the socket, the plug on the left with the yellow wire should pull out of the socket that is attached to the light. Does anyone know how they come apart, I've tried pulling, squeezing, poking but I can't get them apart. Embarassed
Post #505935 21st Feb 2019 7:18pm
fisha
What does the other side look like ?
A lot of those little connectors need something pushed to undo the retention clip and they dont always have a lever to do it. It looks like you've tried that on the centre hole on the right hand part.
An alternative is to lever a very thin small screwdriver in from the left side into the gap between each to push the right hand side outwards enough to let go of the retention clip. V8 or else ...
Post #505941 21st Feb 2019 8:16pm
mjdronfield
Can’t you tell from the connector on your new light how it clicks together? Though I imagine you’ve looked at that already..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #505943 21st Feb 2019 8:30pm
mjdronfield
In this video.... about 2 min 42 seconds in...
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #505944 21st Feb 2019 8:40pm
Cavalier
Thanks for the video. I've worked out how get the plug out of he socket. Just pull the plug very hard while holding the socket still. ITS A PUSH FIT PLUG Thumbs Up
Post #506025 22nd Feb 2019 2:43pm
