Home > Wheels & Tyres > Tyre sizes
Beemergriff
Tyre sizes
My 2010my L322 is currently running on 20" original 10-spoke wheels with Pirelli Zero 255/50R20 (LR OEM size), but as I go green-laning, and also tow my trailer onto off-road sites, I want something with a bit more grip.
My preference is General Grabber AT3. However, the closest size they do is 255/55R20 which will increase the diameter by 1" though width will be the same.
I have measured carefully and clearance under the wheel arches should not be a problem, but does anybody have any experience of fitting slightly bigger tyres? Andrew
Defender 300tdi
RR Classic Off-road Trialer
BMW X3 E83
BMW 330 E46 convertible
Post #506741 28th Feb 2019 9:53pm
Rob99
Lots of L322 owners switch to the 55 profile and actually its more accurate speedometer wise than the 50's 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #506743 28th Feb 2019 9:56pm
Rob99
This will help to compare sizes
https://tiresize.com/calculator/ 2021 D350 Fifty Edition - Carpathian Grey
Post #506745 28th Feb 2019 9:59pm
ianmacd
United Kingdom 2010 Range Rover Vogue TDV8 Epsom Green
Probably because the speedo deliberately overreads. Mine is set to 2MPH IIRC from the CCF. Current: RR L322 2010
Past: RR L405 2017, RR L322 2012, 2008 & 2004, 2018 D5, 2016 Defender, 2011 D4, a few Disco2s, P38, RR Classic, couple of Disco1's, SIII SWB
Post #506750 28th Feb 2019 10:45pm
As above - the 255 55 20 are a standard size on the L405 so are readily available and cheaper than 255 50 20's - so quite a few people have fitted them to L322's with no problems at all.
Post #506766 28th Feb 2019 11:44pm
CS
My 2012 WM latterly had Goodyear 255/55R20 on 405 style 502 wheels. No problems as regards fit/rubbing. Speedo was almost exactly accurate per Road Angel Gem device, almost to the point of under-reading. Steering a bit slower than the 255/50R20 standard size. Ride quality will vary depending on tread design etc - the standard Continentals have soft sidewalls and so ride a bit softer than all terrains like the AT3 (or Goodyear Duratrac which I use in winter). Only Range Rovers since 1988
Post #506825 1st Mar 2019 12:43pm
