![]() | Home > Technical (L322) > Transmission query |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2948 ![]() ![]() ![]() |
I lost drive on my TD6 a couple of weeks ago and had to be recovered home. The car reversed off the trailer and onto my driveway where it’s remained ever since.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1033 ![]() ![]() |
If you place a (5A) fuse in position 37 in the fuse box in the glovebox and switch the ignition on, the transfer box should move into Neutral. Even if your transmission is stuck in Park for whatever reason, this will allow the vehicle to roll.
Thanks Phil. I’ll try that. |
Put the fuse in but still won’t roll. It could be the brakes stuck after two weeks though so we will attempt a tug when the tow truck arrives |
