Home > Technical (L322) > 2012 headlight removal
SFM
France 2012 Range Rover Vogue TDV8 Rimini Red
Hi again
I’m trying to get the headlights out of my 2012 rangey
So as I can alter the beam pattern.
I’ve taken the 3 retaining bolts off, but unit will still not come out, can someone tell me what I’ve missed please?
Post #506830 1st Mar 2019 1:17pm
front bumper off first...
please change your forum car profile.. Wink
Post #506833 1st Mar 2019 1:21pm
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
Hi SFM,
Is this to place into 'tourist' mode? If so, you do not need to remove the lamps.
Or, are you looking to modify the internals to pass the French equivalent of an MOT?
Post #506835 1st Mar 2019 1:23pm
SFM
Tommy
Tourist mode please
Post #506843 1st Mar 2019 1:47pm
up for uk, down for france...
all in the owners manual.. Thumbs Up
Post #506844 1st Mar 2019 1:50pm
TDV8_Tommy
Unscrew the black circular disc/cover at the back of each lamp.
Peer inside (trickly angle) and you'll see a white plastic piece. Move the piece up or down to flatten the beam. It will probably be stiff and feel like it should not move, but a bit of wiggling will free it and you hear it 'clink' the piece of metal within the lamp change to flatten the beam.
It's a rubbish design. Park against a wall so you can see the difference in the beam pattern.
Driving from Calais to Alicante, I didn't get flashed or stopped so I know they work!
There is a clip on Youtube but its no help at all. So ignore it.
Post #506845 1st Mar 2019 1:51pm
SFM
That was easy
Cheers chaps!
Tommy how did you get on with your speedo?
Post #506849 1st Mar 2019 2:07pm
TDV8_Tommy
She is in the body shop still, if as soon as I get her back I will be having a fiddle again with the speedo.
Could be later today. Miss her!
Post #506853 1st Mar 2019 2:26pm
