![]() | Home > Technical (L322) > Change access height only with IID BT tool? |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2948 ![]() ![]() ![]() |
As per title. I can do it on my old non BT on my TD6 but a YouTube video I saw this morning suggests that changing the height affects normal height and access at the same time. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35841 ![]() ![]() |
you can on your 2002....you cant on the 2006 onwards as it does all height modes .. |
Well that’s a bit crap isn’t it? Thought the BT tool was all singing all dancing! |
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 230 ![]() ![]() ![]() |
It is not a fault of the tool it is the difference in how the EAS system is designed between the model years |
I guess so. I think I automatically assumed the basics on the car were the same throughout. |
Full Fattie Member Since: 10 Aug 2018 Location: Sunderland Posts: 245 ![]() ![]() ![]() |
I too was disappointed with this. I’d planned on lowering the access height quite a bit to assist with getting the kids and seats in and out. In reality it didn’t really matter much as the front doesn’t go down all that low, even when dropped to bump stops. The back goes very low though. |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2291 ![]() ![]() ![]() |
I thought you can set the 3 height modes on the BT by calibrating the normal height (185??) and setting the 3 heights in + steps and minus steps...? Be aware I'm not a tech at all. |
Apparently not. One height setting only |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6428 ![]() ![]() |
@ Robert
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2753 ![]() ![]() |
I produce an add-on kit that uses a rotary switch to select low, off, medium raised or high raised with any height mode which makes it easy to go lower in access height. However its costly just for occasional use but if the need is pressing enough then maybe worthwhile. PM me for details if interested. |
