Home > Technical (L322) > Tdv8 injector ordering
ptaroni
After finding out the hard way the injector numbering when looking at cylinder balances i thought i would post this up to help others out.
After alot of googling i could not find out wether injector 2 was in cylinder two or in firing order meaning cylinder 5....
Luckily the injector was the same wether in cylinder 2 or cylinder 5!
Yes i put it in cylinder 2 first Sad then put old cylinder 2 injector into cylinder 5 and all was good!
So basically as on live data the injectors from cylinder 1 to 8 is in firing order meaning
Injector 1 ------ cylinder 1
Injector 2------ cylinder 5
Injector 3-------- cylinder 4
Injector 4 -------cylinder 2
Injector 5 -------- cylinder 6
Injector 6 --------- cylinder 3
Injector 7---------cylinder 7
Injector 8--------cylinder 8
Drivers seat passenger seat
Cyl 4 cyl 8
Cyl 3 cyl 7
Cyl 2 cyl 6
Cyl 1 cyl 5
Bonnet
Hope this helps someone out and if anyone has time and can condense it down a bit more so its easier for everyone to read that would be great!
[/img] 2004 td6 l322 - gone
Now 2007 tdv8 l322
Post #507022 2nd Mar 2019 6:29pm
Like this ?
Post #507024 2nd Mar 2019 6:47pm
ptaroni
Perfect that! 2004 td6 l322 - gone
Now 2007 tdv8 l322
Post #507025 2nd Mar 2019 6:50pm
