![]() | Home > Technical (L322) > IID causing reset of everything |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2948 ![]() ![]() ![]() |
Guys is this normal?
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 547 ![]() ![]() ![]() |
Did you have an external power supply connected? 2016 Skoda Octavia VRS Estate
I *think* a reset is normal with a change to CCF, it was the failure I was concerned about. 2016 Skoda Octavia VRS Estate
No |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35841 ![]() ![]() |
you need to have the engine running...it will stop and start during the process, this is normal.. |
I did. It switched off the ignition and restarted it. Then it all went off and the clock wound back |
good..the reset is a pain but it doesnt take long to set the clock etc.. |
