Home > Maintenance & Mods (L405) > Front suspension maintenance
160dmb
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
I have a 2014 L405 SDV8 with almost 90,000 miles - it runs beautifully except the knocking in the front suspension that is common.
The front anti-roll bar bushes have been replaced and that made a big difference but some knocking still remains mostly noticeable on rutted surfaces and sleeping policemen. It is under extended warranty so I am hoping that the warranty company will address the struts and valve block at the next service but I am thinking I will get charged for changing a set of lower wishbones first due to the mileage.
I could do the wishbones myself and am tempted to do so before the service to save some money - I understand that it is generally the lower front wishbones that need replacing first. Can anyone confirm?
I will do both sides, and will likely buy complete wishbones rather than just changing the bushes - mostly because the ball joints will get changed then as well.
Thoughts and advice please. I know that Cam Tech Craig got the whole strut/valve chest change done at 78/- ish miles - anyone had it done at higher mileages than that? I am always fearful I get a "wear and tear mate" answer.
Thanks
David 2016 (L405) Autobiography in Black with Ivory - for ULEZ
2014 (L405) VSE in Black with Ivory
2011 (L322) VSE in Black with Ivory
2005 (3.2 V6) Porsche Cayenne in Black with Savanna
1999 (P38) VSE in Burgundy (?) with Sand
Post #508006 8th Mar 2019 5:50pm
aljo
United Kingdom 2019 Range Rover Vogue SE 2.0 PHEV Santorini Black
you might want to have a look at this Thumbs Up
https://www.fullfatrr.com/forum/topic50458.html Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #508014 8th Mar 2019 7:32pm
160dmb
Will listen tomo when the family go out. Thank you. 2016 (L405) Autobiography in Black with Ivory - for ULEZ
Post #508042 8th Mar 2019 11:09pm
Buz1500
United Kingdom 2019 Range Rover Autobiography SDV8 Carpathian Grey
I had the same issue and was told by my local dealer that it was wear and tear and not covered under warranty. This was on a 2013 SDV8 with only 40k miles and only 3 months into a 2 year LR used warranty. I then took it to a dealership linked to the one where I purchased the car from and they replaced everything under warranty. 2019 L405 SDV8 Autobiography
2023 Defender P400e HSE X-dynamic - gone
2020 Defender P300 SE - gone
2019 Jaguar F-Pace SVR - gone
2013 SDV8 Autobiography - gone
2011 L322 TDV8 Vogue SE - gone
2006 L322 3.6 Vogue Se - gone
1999 P38 4.0 se - gone
199? Classic 3.5 - gone
Post #508055 9th Mar 2019 9:09am
