Home > Technical (L322) > Tdv8 strange behaviour when pulling off |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
I had a very similar symptom around a month ago. Blanked and mapped out my EGR valves after changing trans oil, diff oils etc.
9th Dec 2018 1:49pm |
ptaroni Member Since: 20 Dec 2015 Location: leicestershire Posts: 89 |
Did as above and it worked! Previously cleared adaptions not long after changing the transmission oil using iid tool but this time i used a snapon modis ultra and that had a relearn procedure which involved driving with gentle throttle through every gear then stopping and holding the brake for 10 seconds 3 times. After doing this and a couple of journeys it is now perfect! 2004 td6 l322 - gone
17th Dec 2018 10:25pm |
2007 Vogue TDV8 in Zermatt Silver with Charcoal |
17th Dec 2018 10:55pm |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 385 |
Mine seems to have similar symptoms and I'm thinking of resetting the gearbox adaptations, but I keep reading horror stories about doing it.
12th Mar 2019 8:41am |
As I understand it, the adaptations should not be reset at the same time as a trans fluid change as it compensates for wear in the clutch packs as well as driving styles. I left mine a few hundred miles after a fluid change before resetting it. It worked for me. My fatty felt like the handbrake was on until around 2000 rpm then released. Now it pulls right through the rev range. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
13th Mar 2019 2:12am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
kooky_guy, you my try driving car in the S mode for 5/6 days, it will reset adaptacion for D mode . did this on mine some time ago and it works really well. you have to drive only in S mode for this to work. 2012 TDV8 Black Edition
13th Mar 2019 11:33am |
That might be worth a try, although a lot of my driving is on dual carriageways and it's reluctant to change into the higher gears in Sport mode. 2010 4.4 TDV8 Vogue SE |
14th Mar 2019 8:39am |
