![]() | Home > In Car Electronics (L322) > Convenience opening /closing |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3270 ![]() ![]() ![]() |
Yes the facility is there. I can't remember if it has to be turned on or not in the CCF but I think it has to be. Peeing down here at the moment so won't go out to check! |
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 358 ![]() ![]() ![]() |
It does, according to the handbook anyway for my 2011 model.
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 ![]() ![]() ![]() |
Usually always turned on - unless customer requested it be turned off in PDI. (IID can turn it back on!) Land Rover Addict
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4345 ![]() ![]() ![]() |
Press and hold unlock button on fob to open all windows and sunroof. Try it |
..and press and hold lock to close them again |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6426 ![]() ![]() |
and then find you have drained your battery enough to prevent starting!
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 ![]() ![]() ![]() |
Yeh also if you lock with the key when windows are down and hold the key it will close the windows and vice versa to open |
