Home > Technical (L322) > Are these gremlins linked
Teaspoonasaurous
United Kingdom 2002 Range Rover Vogue Td6 Alveston Red
Hi,
My 02 vogue has a few minor electrical issues. I am trying to work out if its the bcm or if they are all independent.
The first is that the doors don't lock automatically when you go over 30km any more.
Second is that the rear window behind the driver seat occasionally develops a mind of its own and opens. Yesterday I turned on the windscreen heater and low and behold the rear window opened.
On the same door the locking mechanism has a tendency to be a little bit slow. Some times it is unlocked but on the first pull of the handle the door doesn't open. It will usually open on a second tug.
Last issue, which I think is seperate is that the mirrors are no longer folding. i think that is to do with the passenger mirros micro switch.
IID tool isn't showing anything that would cover these. Is it the BCM?
Thanks
Post #508543 13th Mar 2019 10:59am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Could it be corrosion in either the switches in the driver's arm rest, or the connector on the BECM?
Wonder if there is damp or something in there, I would say that if the BECM had an issue then the IID tool would find some codes. Of course I could be wrong! Formerly happymadison1978
Post #508566 13th Mar 2019 2:19pm
rjff
There is a post on here about mirror microswitches giving problems, here's one
https://www.fullfatrr.com/forum/topic36213...rror+micro
^+1 on corrosion.
I think the IID tool has a section to activate/deactiate the drive away door locking. Perhaps reset using that Unsure about the 02 cars, but the 11my has a drive away locking on/off in the car's screen menu. Cheers
Richard
Gap IIDBT
Post #508594 13th Mar 2019 5:32pm
Teaspoonasaurous
Interesting I may have cleared that doing a hard reset. I have to prise the mirror covers off and have a look this weekend.
Post #508598 13th Mar 2019 5:41pm
rjff
Thumbs Up Cheers
Richard
Gap IIDBT
Post #508602 13th Mar 2019 5:55pm
