Home > Maintenance & Mods (L322) > +9A owners - What does your lower glovebox light look like ?
Changed the bulb on mine the other day, get the feeling something is missing, but not sure what ?
The two press fits for the switch/bulbholder are just there, no finisher, and there is no perspex cover for the bulb.
Is yours like this?
9A onwards only cars.... .
Post #508714 14th Mar 2019 4:48pm
MarianaWestminster
My 59 plate glovebox light is the same as yours no cover/lense or anything.
Post #508791 15th Mar 2019 9:58am
Thank you MW
All just looks a bit shoddy and unfinished, but if that is what it is.
Perhaps no cover so you can attempt to change the bulb without dismantling the glovebox? .
Post #508797 15th Mar 2019 11:12am
MarianaWestminster
I tried for a good couple of hours to change the bulb through the little opening but there was absolutely no chance not with my fingers anyway.
Ended up taking it all apart to fit a new LED bulb.
Post #508820 15th Mar 2019 1:58pm
OK, on the basis of no further information, I will give this up as a bad job by LR Evil or Very Mad .
Post #508982 17th Mar 2019 12:58pm
V8 Bob
Spent a couple of hours fitting led bulbs to interior, sun visors, puddle lights, number plates and reversing lights. Then came to glovebox and yes it’s the same as shown above.
So what do you have to take apart to get access? Thanks 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #518946 18th Jun 2019 7:54pm
I did a short (written) howto here:
https://www.fullfatrr.com/forum/post508162.html#508162 .
Post #518964 18th Jun 2019 10:16pm
V8 Bob
Thanks took off side panel on centre console and 10:tor’s screws managed to get it down far enough to get light out on wire and new bulb fitted. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Post #518966 18th Jun 2019 10:45pm
