![]() | Home > Maintenance & Mods (L322) > Rear Wheel Arch corner rust! |
Fraynizzle Member Since: 27 Apr 2015 Location: Essex Posts: 111 ![]() ![]() ![]() |
you can get rust converters that should stop it getting worse but you may need to expose a lot more of the surface under the paint to get all of it. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4342 ![]() ![]() ![]() |
I'd probably put a light smear of grease over it to keep it at bay for a month or 2 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Full Fattie Member Since: 10 Aug 2018 Location: Sunderland Posts: 245 ![]() ![]() ![]() |
This was mentioned in another thread recently and I said I didn’t know of anywhere that sold repair panels. Has anyone found any in the past. These seem to be more and more common as a problem area, this and the sill. |
Ian928 Member Since: 16 Aug 2016 Location: Kristiansund Posts: 82 ![]() ![]() ![]() |
I have the same thing, You can be pretty sure that needs welding. I hoped it was just surface rust, but when I started to sandblast the area there was lots of pinholes through the body.
kimlahti Member Since: 14 Oct 2015 Location: Oulu Posts: 85 ![]() ![]() ![]() |
I had only small bubbles visible on paint and it was like lace underneath. |
