![]() | Home > Technical (L322) > Went to start but just a click |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35841 ![]() ![]() |
battery or the start of the starter failing... |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3880 ![]() ![]() ![]() |
Try switching the windscreen wipers on and off next time it happens, then try starting it again.
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 ![]() ![]() ![]() |
Thanks Stan,
Interesting?? Could you elaborate some? Regards Daz ------------------------- 2011 (61plate) 4.4 tdv8 sumatra black previous cars e46 m3 e53 x5 |
The “clunk” then nothing is a very common fault.
Interesting theory.
The very act of locking and unlocking the car probably would in effect be the same, and “blow away” the fault., allowing you to then start the car.
Thanks mike |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1425 ![]() ![]() ![]() |
My 2012 WM had exactly the same (battery fine but occasionally just click when button pressed) and it was cured by replacing the starter motor, it's a known weakness. Only Range Rovers since 1988 |
