Home > Technical (L322) > Water Leak
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
Water Leak
Afternoon all
Have noticed a slight water leak over last few days. Steady drip from under car in region of gearbox. It's def water although not sure where it could be coming from. No information coming up on dash regarding low water levels. I'll be getting underneath car tomorrow to have a better look but wondered if anyone has ideas on what it could be.
Cheers FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #54119 11th Mar 2011 6:04pm
Is not just the A/C as they are meant drip away the water they evaporate?
Post #54121 11th Mar 2011 6:07pm
GregP
Could well be. I always have A/C on as recommended but only just noticed this drip. Just went out again and it's still dripping after 50mins of car being parked after journey. FFRR TD6 HSE
Post #54125 11th Mar 2011 6:16pm
Get under and see exactly where its dripping from.....
Post #54131 11th Mar 2011 6:29pm
GregP
I'll take a good look tomorrow as car is in garage having a check over anyway.
It better not be anything serious FFRR TD6 HSE
Post #54134 11th Mar 2011 6:42pm
hope its not to serious greg... Thumbs Up ... - .- -.
Post #54139 11th Mar 2011 6:46pm
dan_uk_1984
There is a heater hose at the very back on the engine that goes into the heater valves that can fail. But as already suggested I would bet on your AC. The evaporator can get a lot of ice build up on it, and it doesnt defrost that quickly in these temps.
Dan
Post #54153 11th Mar 2011 9:03pm
daveo
silly question..have you noticed you have lost water of had to topped up you exp tank.. V8 facelift Range Rover Autobiography 22" wheels.
Post #54157 11th Mar 2011 9:30pm
Greg
If you havent noticed any loss of coolant from the expansion tank i wouldnt bother worrieing. Now if you coolant level is falling then it could be the hose's at the back of the engine, or could be the valey pan gasket. Now the hose's are the easiest to replace but the valey pan isnt the end of the world either. Have a search for coolant leak as i have recently pasted about the valey pan seal leak. common problem with the M62 engine. Mine has a leak in the same area and its the valey pan thats leaking. Not to much of a problem just need to keep ontop of the water. When payday comes the seals and gaskets will be ordered and will set about sorting the leak.
Rob
Post #54164 11th Mar 2011 10:25pm
GregP
Thanks all
I'll report back tomorrow. Lets hope its just AC. FFRR TD6 HSE
Post #54166 11th Mar 2011 10:44pm
GregP
nope, no loss of water noticed. Everything seems fine. FFRR TD6 HSE
Post #54167 11th Mar 2011 10:45pm
GregP
Good news peeps, it was just the A/C Smile
In addition to that the new wheels & tyres are on and look class (pics to follow soon), new oil sorted and had all engine electrics reset so car can learn the way I drive.
Only done 20miles since but mpg has gone through the roof. Normally flirts around 21-23 and just got 28-30!!!!! Thumbs Up FFRR TD6 HSE
Post #54272 12th Mar 2011 5:29pm
thats dan's fault for getting you worried like that...leave the a/c off now. Very Happy
dont get to excited about the mpg greg, mine went like that after my remap but soon settled down.. Crying or Very sad ... - .- -.
Post #54275 12th Mar 2011 5:34pm
GregP
I haven't had it remapped yet Smile
Just had it plugged into autologic gizmo and a few things sorted and reset to original settings. I don't really understand what he was doing but he said it should help with mpg. Gunna get the autologic remap in a few weeks I reckon. I'll keep an eye on mpg as I do expect it to calm down but hopefully it will stay above what I got before. FFRR TD6 HSE
Post #54276 12th Mar 2011 5:40pm
