Home > Technical (L322) > door locks
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
door locks
some time ago, i locked the doors with the key
the buttons on the key don't work
i then couldn't open the doors
later, my son came and opened the doors with the key, just like normal
sense then i haven't been game to lock it
however as i am now getting close to getting it on the road i thought i had better look in to it
taking one of our members advice, i closed the drivers door lock with a screw driver while holding the door open.
i then locked the doors with the key, all the windows went up and the doors locked.
i then tried to open the doors, but only the drivers door would open.
after a lot of key turning and messing about, the drivers side doors will open but the passenger side and rear doors are locked.
i have read the book and still none the wiser
there is a way of opening the rear door in an emergency, BUT you have to be inside the car to do that.
any ideas on this
i know i am probably missing the obvious
thanks RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #510223 29th Mar 2019 2:22pm
knares
hmmmmmmmmmmmm RR 2005 4.4 petrol
Post #510374 31st Mar 2019 7:30am
its possible that the key has been programmed to only open the drivers door on the first press and all doors on the second press..
Post #510375 31st Mar 2019 7:40am
knares
thanks Stan
after all the twisting and turning of the key with three of so trying the other day.
i went out this morning, put the key in the lock, turned it three times in a clock wise direction and the left hand and rear doors opened RR 2005 4.4 petrol
Post #510471 1st Apr 2019 4:09am
