Home > Technical (L322) > Drivers window was intermittent now stuck Down
Hammer
Australia 2007 Range Rover Vogue TDV8 Zambezi Silver
I should have stopped using the the drivers window when it would only work intermittently. Sometimes i would start the car and it would go down and had no problems going up. Then occasionally I would start the car and it wouldn't work. Now it is stuck down.
I can hear the sound of a relay clicking when i operate the switch, I have tried lazy lock and all the other windows work.
I searched hi and low on the net and have found similar posts with similar diagnoses but have then the solution has not been posted.
RRRR Looks like door card off
Any suggestions appreciated. 2015 AB 5.0 Supercharged
2007 TDV8 Vogue
2000 P38, Gen3s, 2 inch lift, KM2s 285/75/16
Post #510284 30th Mar 2019 6:30am
mpirie
Have you tried the global open/close by holding the lock/unlock buttons down on the remote?
If the relay is clicking and there's no movement of the glass, then either the quadrant has siezed (possibly burning out the motor and/or fuse) or the motor has had enough.
Mike
Post #510287 30th Mar 2019 8:03am
Some diagnostic machines (like IID) will allow you to open/close windows through the service menu... This allows you to diagnose weather its a switch or worse Thumbs Up
Post #510310 30th Mar 2019 11:24am
Hammer
Thank you for the reply Gents
The issue turned out to be a connector on a non genuine regulator replaced some time ago.
Tested faulty with the ohms meter. Tries to repair the connector but the the break was in the the plastic case.
Cheers Paul 2015 AB 5.0 Supercharged
2007 TDV8 Vogue
Post #510370 31st Mar 2019 3:42am
