![]() | Home > Maintenance & Mods (L322) > L322 tyre inflator (air compressor) |
| Grizzly_Adams Member Since: 11 Dec 2017 Location: Brisbane Posts: 36
Hi all,
| Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 714
The rear Aux socket is a convenient point for plugging a tyre inflator in, but I think is limited to 20A.
| Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1211 |
The Aux socket in the boot is ok to use, but you have to keep the engine running as it's linked to the timing shut down on the computers? |
Thanks for all the responses folks, much appreciated |
| wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 808
I presume you will be airing down and up dependent on track conditions hence the question. I have never had an issue connecting an air compressor direct to the battery, earth to body poss to the Aux terminal on the bulkhead, keeping the engine running whilst using the compressor for long periods. You might think of adding a second battery to the rear and connect via a cheap voltage sensing relay to the existing heavy Poss cable feeding the rear fusebox. If you rewire the rear aux outlet direct to the second battery it takes away any chance of flattening the main. 2007 TDV8 VSE
Yeah that's the idea. I've got the Defender set up with all that kit but not the RR yet, a second battery is definitely on the list of things to add |
