Home > Maintenance & Mods (L322) > Deployable steps - fuse and control module locations |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1097 |
Have they simply been turned off? Current: 2011 FFRR Vogue SE 4.4 TDV8
1st Apr 2019 11:33pm |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 527 |
I asked that when I took the car back to them and was told "they cannot be turned off". How would I turn them on if they have in fact been turned off? Looked with the IID tool and found nothing obvious... Mike - MPx
1st Apr 2019 11:46pm |
Well it's in the book (apparently)
2nd Apr 2019 7:55am |
That's very helpful thanks Bushy30....and has even gotten me to break out the manual(!) Doh! Sadly to no avail. I get no light on the switch no matter what I do with the ignition or how long I hold it for. I noticed they could have been inhibited through terrain response as well (not that the car is currently in any special program) but that had no effect either. The symptom looks like complete lack of power. Mike - MPx
2nd Apr 2019 9:12am |
Having fitted them as a retrofit -- I'm not sure where stuff is from a factory fit, so I'm not much further help -- I don't even know what fuse it uses, but it must pre-exist for other things too as when retrofitting you don't fit a fuse!
2nd Apr 2019 9:28am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34939 |
what was yours in the MD for ? |
2nd Apr 2019 9:49am |
Thanks again anyway Bushy30.
2nd Apr 2019 11:08am |
definitely sounds like their diagnosis process killed your steps..
2nd Apr 2019 12:13pm |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
Did they use gold plated tools???? This is why I never use a main dealer for things like that. It's a joke! Land Rover Addict XXXXXXXXXXXXXXXXXXXXXXX Previous XXXXXXXXXXXXXXXX 2009 5.0V8SC Autobiography 2006 4.2V8SC Autobiography 2004 4.4V8 Vogue |
2nd Apr 2019 12:22pm |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1133 |
this could help? https://topix.landrover.jlrext.com/topix/service/document/70569
2nd Apr 2019 12:31pm |
Very helpful thanks Tinman. For the MY10 on shows the power take off from Pin 19 as Bushy30 said and the control module should be behind the panel in the drivers side footwell. Seems unlikely that they would have taken anything significant apart inside so will check the easy to see connectors as Stan suggests. I guess they could have fried the control module (or it coincidentally chose the moment of their tenure to give up)...or something else has become disconnected. Apart from the steps the car is all good at the mo so unlikely to be a shared fuse. Will try to do some further investigation later as long as the rain holds off... Mike - MPx
2nd Apr 2019 1:23pm |
IF it is the module its easy to get to just a few screws you can check out in the Wiki for fitting tips |
2nd Apr 2019 1:32pm |
Right had another delve about. The connectors were all connected although the nearside one by the step motor has obviously been separated recently and hadn't been put back properly onto its mount. Took the footwell panel off and the control module was there as expected. Put my meter onto the big red cable and there was 12.6v present so at least I know there is some power in the steps loom. Further investigation on the module is well above my pay grade but I didn't get any voltage reading on any wire in the "other" plug to the one the red wire was in so that may indicate its toast? Interesting to see that its a Ford branded unit.
2nd Apr 2019 4:57pm |
Just a thought have you taken the motors off to see if they fire up and its the steps that are seized or check that the steps move manually? before you fit steps you have to fire them up to open them to fit the car. |
2nd Apr 2019 5:41pm |
