Home > Technical (L322) > TDV8 3.6 problems no heating and hot feet
brain123
Germany
Dear members, my ac / heating is completely down. Fuse 34 keeps on blowing. Initially it worked with simply replacing the fuse. But this doesn`t work any more. Could this be related to:
=> a bad sensor in the vented seats (vogue model) ? Would I get certain error codes in case of a bad sensor? Is there more than one? And how can I access them.
=> or a component in the center console /rear AC Switch pack? How do I access that?
=> Anything else?
After 20-30 miles of driving on a motorway I get hot feet . Hot air comes out of the front air vents footwell. Tough with no way to manipulate it and AC down Sad
I can also feel that the center interior paneling on the RH-side (footwell) - next to the glove box and under the infotainment gets fairly warm/hot right at the top. Blower is not working.
Questions:
a) how could one stop that hot air stream from the footwell? Default setting that can be changed?
b) Any risk for the harness... if hot air keeps not circulating?
By the way : Out of the rear ac/heater vents comes a breeze of cold air???
Any idea/experience?
Thanks for your help
Post #510948 5th Apr 2019 6:40am
Final Stage Resistor (hedgehog / FSR) ? .
Post #510974 5th Apr 2019 9:20am
brain123
Germany
Dear Joe90,
Thanks for Input would the FSR cause the fuse 34 blowing? Any other fuses to ckeck?
Any good advice to stop the hot air streaming out of the front vents footwell - can this be manipulated or turned off while pursuing the search for the error
It is a tdv8 vogue make 2007
Thanks again in advance
Post #511201 7th Apr 2019 9:16am
