Home > General > 100000+ miles
Peopete
100000+ miles
What things do I need to look out for on a 100000+ mile 4.4 or 4.2sc. All advice appreciated
Post #511027 5th Apr 2019 4:30pm
There’s a buyers guide in the Wiki
The wiki link is top right under where it says fullfatrr.com Thumbs Up
Post #511033 5th Apr 2019 5:01pm
Peopete
Thanks Thumbs Up
Post #511034 5th Apr 2019 5:03pm
Clearly the older the car / higher the mileage, the more regular servicing and maintenance matter.
Ideally you’d want to see things like all fluids changed at around 60k - diffs, gearbox etc.
I usually look for little things - my starting point is 4 matching tyres from a mainstream brand - it’s an easy check and skimping on tyres means there will be corners cut elsewhere - and not something a quick valet will cover up.
Post #511039 5th Apr 2019 5:28pm
Peopete
Thanks alistair, is a specialist garage service history as good as a JLR history?
Post #511045 5th Apr 2019 6:02pm
IMHO it’s better
As soon as mine are out of warranty I take them to my local guy who I trust 100% and does everything top quality
Main dealers are (in my experience) box checkers who don’t know that much - the service manager may be good, but the grunt trainee doing the service work is next to useless.
As long as the right fluids are used, then I’m happy - plus other things like genuine OE brake pads, but they don’t need a main dealer to fit them.
Post #511048 5th Apr 2019 6:43pm
Peopete
That's what I was thinking, I'm not sure if there is a good independent in Birmingham but I will do my home work, in only 10days away from having the readys to get my 4.4 or 4.2sc, then the lpg fitted Thumbs Up
Post #511050 5th Apr 2019 6:53pm
Read the LPG threads as well then.
The BMW 4.4 seems bullet proof. The Jag 4.4 or 4.2sc seem to require a better quality conversion - I say that from casual acquired knowledge, never having had, or even been interested in LPG.
Example thread - but there are plenty of others.....
Post #511051 5th Apr 2019 7:01pm
Peopete
What year did the jag 4.4 start? I've read the lpg forum it's good, I've got a holiday home in mid wales so a lot of miles will be clocked up hence the lpg and th v8 rumble Thumbs Up
Post #511054 5th Apr 2019 7:13pm
I think late 2006 - it came with the facelift as Ford had bought Jag & LR and so replaced the BMW bits where they could.
The Jag 4.4 petrol is pretty rare though.
I use the channel tunnel regularly so LPG is a non-starter for me.
Post #511060 5th Apr 2019 7:56pm
Peopete
Is yours the BMW 4.4? Are you pleased your rr and reliability?
Post #511061 5th Apr 2019 8:01pm
I had a BMW engined 4.4 many years ago and loved it.
The TD6 diesel at the time sucked IMHO - however, things changed with the TDV8 and I’ve been a fan (and owner) ever since.
My latest Thumbs Up
Post #511064 5th Apr 2019 8:17pm
Peopete
Nice car alistair and thanks for the information and advice Thumbs Up
Post #511065 5th Apr 2019 8:27pm
Dolphinboy
United Kingdom 2011 Range Rover Vogue TDV8 Atacama Sand
If u look at the what’s your mileage thread, you’ll see a lot of the top 10 or 20 are 4.4 petrol and a lot have lpg.
The only thing that might catch you out is the chain guides. This can cost £2-3k. If it’s been done then you are on a winner.
Post #511097 6th Apr 2019 8:53am
Peopete
Ouch! Could you have that same problem with a 4.2sc or is it just the 4.4 that has the chain guide problem?
Post #511100 6th Apr 2019 9:25am
