Home > Technical (L322) > 2006 L322 Supercharged - knocking sound and rough idle
Ian928
Norway 2006 Range Rover Supercharged 4.2 SC V8 Java Black
This morning my 2006 SC was hard to start and had a knocking noise. I tried to start it 3 times with the same result before leaving it at home. I am looking for tips on where to start. I do have a IIDtool. Here are the symptoms:
    Parked yesterday evening, no suspicious sound or anything
    Hard to start, first low idle, stutter, then highish idle
    Blipped the throttle, I am unsure if it is running on all 8
    Knocking sound from engine, same frequency as rpms, not unlike hydraulic lifter but I have heard a couple of lifter on cold mornings on this car and it is not the same sound
    Smell of fuel from exhaust
    Oil on dipstick
    No engine lamp
    2 out of 3 starts brought up "traction reduced" message, that might be coincidental as I sometimes see this when it is cold
 2006 Supercharged
Post #511296 8th Apr 2019 8:12am
Ian928
Just got home from work, started the car, ready with stethoscope. After a coupe of seconds, the knocking faded away, there was a small misfire for another 10-20 seconds before everything now seems to be as usual.
Any ideas? 2006 Supercharged
Post #511356 8th Apr 2019 5:07pm
Weegie
Dirty injector which has cleared? John
GAP iiD BT-Sold
Post #511357 8th Apr 2019 5:23pm
Ian928
Maybe... can it lead to knocking sounds? Maybe it was excess fuel igniting in the exhaust manifold?
A stuck open injector would explain the fuel smell. 2006 Supercharged
Post #511372 8th Apr 2019 7:42pm
