Home > Technical (L322) > Sticky Ignition Key
gavinn
Sticky Ignition Key
Hi All
I have a sticky key issue , it appears to be the ignition lock itself , there is probably some dirt gone down it , it is defiantly not he steering column issue , has anyone on this forum removed and cleaned the barrel , from instructions there is a special tool required ?
This is for the Ignition Key on the center console , L322 2006
Cheers
Neil
Post #511667 11th Apr 2019 10:20am
wayneg
Have you tried a puff of graphite powder in the lock or grind down a pencil lead to powder second best. I had a panic a while ago and this resolved the issue. The key position is just asking for debris to find their way in. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #511671 11th Apr 2019 10:34am
couple of 'how to's' in the wiki gavin..
Post #511674 11th Apr 2019 11:10am
gavinn
I can only find WIKI for the steering column issue and the Shift cable , not for removing the lock ?
Post #511686 11th Apr 2019 1:07pm
electronics, third and fourth items..
Post #511688 11th Apr 2019 1:20pm
gavinn
Thanks, but neither of those mention the removal of the key assembly
Post #511714 11th Apr 2019 5:44pm
verydisco
hi,has this trick worked 100% ever since? l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #555362 26th May 2020 3:25pm
