Home > Technical (L322) > Front hand right height sensor
RRV78
England 2003 Range Rover Vogue 4.4 V8 Java Black
Coming home from work in our 2009 3.6 tdv8 and suspension fault pops up on the dash.
At present I only have the icarsoft code reader so plugged that in and it tells me the front right hand height sensors faulty.
So I’ve changed the sensor and reset all fault codes and as I suspected the suspensions all over the place n/s is fine o/s is high at back low at front.
So I’ve come to the conclusion it needs recalibration and that I’m going to have to bite the bullet and buy the bt Iid tool for this job.
So that’s my question if I buy the Iid tool will it recalibrate my suspension? Current: 16 my2016 Range Rover l405 4.4 sdv8 Aruba gold & 11 MY2011 RANGE ROVER L322 4.4 TDV8 ZERMATT SILVER
Previous
59 MY2010 Range Rover Vogue L322 3.6 TDV8 Zermatt Silver
53 Range Rover Vogue L322 4.4 V8 Java Black
98 P38 Range Rover 2.5 DSE Champagne Gold
Post #511683 11th Apr 2019 12:48pm
yes it will [with your help]
Post #511689 11th Apr 2019 1:22pm
RRV78
Maybe a stupid question Stan but other than connecting it with my iPad what other help will it need?
My only experience with suspension calibration was on my old p38 where I had to fit height blocks to set the different heights. Current: 16 my2016 Range Rover l405 4.4 sdv8 Aruba gold & 11 MY2011 RANGE ROVER L322 4.4 TDV8 ZERMATT SILVER
Previous
Post #511690 11th Apr 2019 1:37pm
a tape measure and read the manual [link in wiki] Thumbs Up
Post #511699 11th Apr 2019 4:07pm
RRV78
Thanks stan Current: 16 my2016 Range Rover l405 4.4 sdv8 Aruba gold & 11 MY2011 RANGE ROVER L322 4.4 TDV8 ZERMATT SILVER
Previous
Post #511701 11th Apr 2019 4:26pm
