![]() | Home > General (L405) > Sport mode |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8093 ![]() ![]() ![]() |
On the right roads it makes a real difference - you’re in the right gear to accelerate,out of roundabouts |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3807 ![]() ![]() |
^^thats why it’s called Sport Mode |
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 ![]() ![]() ![]() |
If you want to feel a real difference - put it in sand mode and sport at the same time. (note the gear box will change to manual shift). |
CUE99T Member Since: 02 Oct 2011 Location: Glasgow Posts: 779 ![]() ![]() |
I use it often to just give better over taking etc
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 ![]() ![]() ![]() |
I recently had my 5.0 S/C AB tuned by Viezu, its now circa 560 bhp and 690 Nm, much better ride in D and better again in S, like you say, shame it doesnt afford the slightest bit more noise just to finish off the more sporting ride.
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1528 ![]() ![]() |
@Carlos intriguing, how much was that?
I used their V Switch product, its a handheld device that plugs in to the OBD port, you read for error messages and if all good it reads the cars ECU then send it to them and they send you a tune file to load into the car.
That's brilliant, thanks Carlos!
Its deffo worth a look, I came out of an AMG SUV so my 5.0 S/C felt soft, slow etc. its woken it up quite a lot, feels like a 500+ BHP car now where it didnt before and it needed so much throttle to actually get it going, a real sleeping giant thats finally woke up a fair bit.
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 ![]() ![]() ![]() |
@Crasher242 - for info - I think the apparent slowness setting off in normal 'D'rive is because the car sets off in second gear by default , if I remember correctly. Hence, if you wanted to nip out of a road end without selecting Sport mode, you would downshift manually to 1st gear to get a quicker response if required.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16395 ![]() ![]() ![]() |
There is a device one of my friends had fitted to his BMW M6 which has a dial 1-6 and the throttle changes ferocity! Works VERY well. Ill send him a text now to ask for a name ![]() |
Its a pedal box, basically makes the car think you pressed the throttle much more than you actually did.
Crasher242 Member Since: 07 Mar 2019 Location: Warwickshire Posts: 140 ![]() ![]() ![]() |
I had a play yesterday and think I did notice that it would want to pull away in 2nd as you say. May play some more next week when the bank holiday is over. Current Vogue SE 4.4 SDV8 Previous highlights Many Mini's! Audi S8 Audi A6 Avant (the petrol guzzling Bi-turbo) Subaru H6 3.0 Estate Peugeot 406 Coupe V6 Audi 80 Quattro Sport |
