Home > Maintenance & Mods (L322) > MOT Fail
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
MOT Fail
Big Cry
Car failed its MOT last week on this:
Repair immediately (major defects):
•Offside Front Lower Suspension arm pin or bush excessively worn rear bush rear arm (5.3.4 (a) (i))
Now is it the rear bush on the rear arm or the front lower arm bush?
How much work is involved in replacing this as the local guy who does all our servicing seems to be a bit worried about jacking the car up to do the repair as there is potentially an issue with the suspension (its down at the front). I suspect that a ride height sensor has been knocked or damaged causing the suspension problem.
Any ideas / approx. costs to fix this?
Post #512134 15th Apr 2019 12:38pm
gavinn
Front lower suspension arms are easy, just remember to tighten the bush bolts back up with the vehicle on the wheels, ramp or pit useful for this , i did both on mine myself a few weeks ago , took around 40 minutes a side
Rear bub bushes are OK to do when you have done a few and have the tool to press out the old bush in Situ , you will need a 4 wheel align afterwards .
Parts from Duckworths of course !
Post #512146 15th Apr 2019 2:03pm
PaulTyrer
Update.
Went in again on Monday and passed!! Thumbs Up
Post #512494 18th Apr 2019 10:35am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Great news! Thumbs Up Formerly happymadison1978
Post #512495 18th Apr 2019 10:37am
