Home > Technical (L322) > L322 2011 4.4 TDV8 Suspension / compressor fault
DMRR
FYI I had a brand new replacement do just that. Sent it back and the replacement was fine. They CAN fail out of the box. Do NOT assume new means working Smile Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #512844 22nd Apr 2019 7:21pm
gg2201
Sounds like the same problem mine had. Was the brass exhaust valve. Removed, clean drilled a small 2mm hole in the bottom so it wouldn't block again and it's been fine since.
Not long after that both my front bags died when hooking up to tow our horse box. The drivers side went with a catastrophic bang Laughing
Tbf the bags were so easy to replace literally 45 min job with right tools Thumbs Up 2011 4.4 TDV8 Autobiography
Post #513169 25th Apr 2019 5:50pm
Baz1975
Northern Ireland 2015 Range Rover Autobiography SDV8 Firenze Red
UPDATE
All fixed, intermittent exhaust solenoid valve, not the brass exhaust, the actual vale block with 4 air hoses attached (right beside the air compressor) replaced & driven a couple of hundred miles!
Many thanks for all your help folks.
Baz Current: 2015 4.4 SDV8 Autobiography
Old: 2011 4.4 TDV8.... OMG
Old: 2003 TD6 HSE Java Black
Work: 2016 VW T6 140
Post #514716 8th May 2019 7:13pm
CaifanSC
United States 2012 Range Rover Autobiography 5.0 SC V8 Epsom Green
You wouldn't happen to have a picture of what the little valve looks like, do ya?
Im new to the RR but I have read plenty of posts about this little valve clogging. I'd like to do some preventive maintenance and clean it up and drill the hole...but I'm not quite sure where it's located.
Any help appreciated! 2012 Range Rover Autobiography
91 BMW 850i 6 speed
94 BMW 850 CSi 6speed
Supercharged Tbirds
Audi S8, Audi V8 Quattro
Post #524033 7th Aug 2019 8:30pm
DrRob
https://www.fullfatrr.com/forum/topic23038.html Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #524035 7th Aug 2019 8:37pm
CaifanSC
Hat off to you, sir! Many thanks! 2012 Range Rover Autobiography
91 BMW 850i 6 speed
Supercharged Tbirds
Post #524037 7th Aug 2019 8:45pm
DrRob
“You’re welcome!” as they say over your neck of the woods Thumbs Up Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #524038 7th Aug 2019 9:02pm
woodand
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Baz1975 wrote:
UPDATE
Baz
Hi, Dont suppose you know the part number / technical name for this valve block do you ?
Thanks
Post #551963 28th Apr 2020 3:32pm
rjff
Woody
It' the rear valve block. You should be able to find some info on part number from the microcat links in the Wiki.
PS can you fill in your car profile please, helps us identify things easier. Thumbs Up Cheers
Richard
Gap IIDBT
Post #551968 28th Apr 2020 3:44pm
woodand
Cheers..
Post #551971 28th Apr 2020 4:04pm
rjff
Thumbs Up Cheers
Richard
Gap IIDBT
Post #551977 28th Apr 2020 4:30pm
