Home > Technical (L322) > EAS Pump replacement time?.
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Just had the "EAS inactive & Max 30 mph" warning come up with the height led going off.
It came back on & message disappeared, although the compressor was running for a while & when stopped the front lifted up to normal height.
Whilst checking for leaks (none found), I had the " system will raise once cooled" message appeared. It will raise & lower ok, but the compressor is getting hot. As I've replaced the air reservoir last year, I'm now assuming that I need to obtain a new Hitachi compressor.
I do have one query regarding the heights though, as currently sat in off road height & some heights vary, NSF 54 cm OSF 51 cm NSR 51 cm & OSR 48 cm (drive has a slight slope to it ). Should I be worried about this, or will it sort it self once a new compressor has been fitted?.
Thanks guys.
Post #513369 27th Apr 2019 12:43pm
Highroller
Beginning to think that the compressor is ok & the issue lies elsewhere.
Drove out today & compressor cut in & out as normal, raised & lowered fine.
However had the car raise back to normal height whilst stationary & had the the warning sign " waiting to raise". This is looking more like an air leak, although Unable to see or hear anything (Time for soapy water).
Also had a check of all the height sensors as I was under the rear end the other week, replacing the rear brake flexi pipes & thought that that would cause an issue (coincidental now this is happening).
Any other thoughts?. Sad
Post #513490 28th Apr 2019 5:41pm
Highroller
Well the answer is No!.
Everything was pointing to the NSF height sensor & Just before I replaced it, I lubricated all the height sensors joints with WD40.
Guess what it's all fine Very Happy
No warning messages or bongs, Compressor cuts in & out quickly, suspension works as it should, happy days Thumbs Up
Post #514446 6th May 2019 12:54pm
