![]() | Home > Maintenance & Mods (L322) > Gearbox oil change / megaflush - any recommendations London |
essex boy Member Since: 21 Jan 2017 Location: essex Posts: 214 ![]() ![]() ![]() |
Hi I have just called JT automatics Erith this morning 350 plus vat using ZF oil.I used them a few years ago on my ford explorer good job and price at the time they have been going since 1965 |
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 358 ![]() ![]() ![]() |
Afraid they are East London as well, but Brownchurch (very well known LR/Defender specialists) have done all my servicing for years, previously on the 110, and now on my L322.
WB Member Since: 26 May 2016 Location: London Posts: 303 ![]() ![]() ![]() |
Thanks for the recommendations.
Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1279 ![]() ![]() |
I’m no techie Why and when do you do a mega flush ? Ditto metal sump filter, Why if better don’t JLR fit as standard??? Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc He who dies with the most toys wins... |
My understanding is the Megaflush is a convenient way to change the gearbox oil but the two transmission specialists I've spoken to and ZF don't seem to do it that way so you'll need to come to your own conclusion.
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198 ![]() ![]() ![]() |
WB
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Just my pennies worth , ZF recommend an oil change as opposed to a flush. I'm certainly not an expert but if the guys that manufacture it advise how to change the oil and filter then you couldn't go wrong following their advice.
Sorry to nick a bit of your post WB but:
Hi Richard , i agree sir , i was merely pointing out ZF's own recommendation. I get mine done every 40k kilometres. Indie did say fluid removed smelled and looked like new, which was nice to hear. I also reset adaptations with the wonderful IID tool.
I thought from reading other posts on here as well that the recommendation was to not reset adaptions immediately on changing the oil, but let the gearbox recalibrate itself a bit first? |
I wasn't aware of a need for a delay in resetting the adaptions. I did drive about 50 kilometres before i did it but that was because of a meeting i had to get to and not from any knowledge |
John
Yes to the filter change , indie uses the genuine ZF one. Not mad expensive and gives peace of mind. As i say , I'm far from an expert and i normally follow indies advice unless others on here can offer some wisdom he may not have. Good luck with whichever route you take 2015 4.4 AB
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
The middle ground is for those without the oil changing machine - two (or better three) separate oil changes with a good drive in between to open the thermostat. With a new pan inc filter of course.
