Home > My Range Rover > New member with RR Vogue in Santorini Black
WdeRave
Spain 2010 Range Rover Vogue TDV8 Santorini Black
Dear all,
Like to introduce me as a new member.
Bought a 4.4 TDV8 last November with 161.000kms (185.000 currently).
I live in Belgium and purchased the car in Germany, but originally the RR comes from Romania! Always maintained at a RR dealership and (good for me) without a tow bar Very Happy
The reason for me to purchase this RR are the options:
- Standard Vogue
+ Harman Kardon 1.400watts (or at least enough ....)
+ 360 Camera view
+ DAB
+ TV (and dual view)
+ Adaptive cruiscontrol
+ Blindspot monitoring
+ Fixed sidesteps
+ Shift paddles
In the meantime we did:
- Oil change incl. filter
- Air filter change, were wondering why only one needed to be changed, but due to this forum, we know now!
- Diesel filter change, gained 50hp back that I did not knew I had Thumbs Up
- Front discs (Brembo) and brake pads (TRW), works perfect!
- Rear brake pads and hand brake pads (including springs etc.)
- Cleaned the MAP (very dirty) and MAF (was OK) sensors
- Changed the damper from the tailgate and the rubbers next to the back window (see picture)
- Upgraded the DAB receiver to a DAB+ one, thanks to OldJaguar.com. They have a complete set with bracket, cables and manual, which fits perfectly (not cheap however). DAB+ using the usual screen (see picture)
- New Micheling original JLR tyres
- Mount a new tow bar (see picture)
Things to do
- Remap EGR (get ride of the damn thing)
- Fix the broken "finish" and the damaged sidestep on the right-hand side (finish already purchased)
- Re-install the plastics around the front window. This has been replaced and not correctly installed (they used silicone etc.) to eliminate the noise Cool
- Remove some scratches and a small dent in the front hood
- Repair/change the camera in the front right .....
So still some "improvements" to do, but in the meantime, it runs better with every change we did! It is unreal how fast this "thing" goes and how easy it is to drive. The only challenge are parking garages, that are to narrow or to low. But hey, if that is the only thing ..... RR Vogue, 4.4 TDV8, 10/2010, Santorini Black
(EGR out, 380HP, 800Nm)
Post #513572 29th Apr 2019 3:52pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Looks good! I'm fairly sure you can't delete the EGR on a 4.4 though Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #513573 29th Apr 2019 4:14pm
WdeRave
Hi Bushy30,
Thanks for the reply.
Yes, we have contacted several parties already, all positive about the remap but with different prices. No MOT challenges and will assure I get rid of some "lost power" messages .....
So for me to find the best party to help me with this Smile RR Vogue, 4.4 TDV8, 10/2010, Santorini Black
Post #513640 30th Apr 2019 9:59am
rjff
Very nice looking and much prefer the light interior. Enjoy. Cheers
Richard
Gap IIDBT
Post #513814 1st May 2019 10:07am
Our mappers WONT delete the EGR's as they in turn effect the DPF! And you don't want DPF issues Censored Censored Censored
Post #513820 1st May 2019 10:19am
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
There is a tow bar receiver and electrics, as far as I can see. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #513821 1st May 2019 10:29am
WdeRave
Hi RJFF,
Yes, my favorite color scheme too. Enjoy every mile Very Happy
Hi CAM-TECH-GRAIG,
Thanks, for the reply. Will investigate and take into account! Definitely something to reconsider Idea .
Hi V8Noise,
Correct, we installed it Thumbs Up ! Not an original RR set, but it is removable, new and has the same specs but way cheaper! RR Vogue, 4.4 TDV8, 10/2010, Santorini Black
Post #513830 1st May 2019 11:40am
