![]() | Home > Technical (L322) > Air Con Compressor - how much oil? |
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1099 ![]() ![]() ![]() |
Fairly sure there's a label under the bonnet Current: 2011 FFRR Vogue SE 4.4 TDV8
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 430 ![]() ![]() ![]() |
I was sure it was there -- apologies -- have a look on page 2 here: -
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
Mate, pay someone with the right gear and knowledge to do it. Get it wrong and it will cost a lot more. You can overcharge the system and do damage.
Not blunt, just unhelpful assumptions.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35782 ![]() ![]() |
when you say 'oil' do you mean 'air con gas' ???? |
No, actual oil additional and separate to the gas/refrigerant which is apparently as equally important to get right as the gas itself and does have an impact if it's overfilled or underfilled. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
Did you read the pdf? there's a calculation on page 2! Current: 2011 FFRR Vogue SE 4.4 TDV8
I did and thank you for posting!
My apologies for the assumptions. I just didn't want you to make an expensive mistake and do a diy job.
Thanks, Grofus! |
Ok mate. Makes you wonder why there was so much oil in it. As you know it causes as many issues as not enough.
