![]() | Home > Maintenance & Mods (L322) > L322 rear brake hose replacement |
stuartj9 Member Since: 18 Apr 2019 Location: Liverpool Posts: 86 ![]() ![]() ![]() |
You may have to get some mole grips on the union nut to turn it, or worst case hacksaw/grind through it, then replace union and re-flare the pipe. Before doing so, check that the pipe running back to the front of the car is in good order, that may also need replacing. All in the wiki. .
finchi Member Since: 25 May 2017 Location: Hampshire and Cheshire Posts: 120 ![]() ![]() ![]() |
I would only fit JLR rear brake hoses as "copies" can have issues with rubbing against wheel assembly components.
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 570 ![]() ![]() ![]() |
Just changed my rear pipes & also had issues (Yours look worse than mine). I soaked them all in penetrating oil & still had issues. |
You haven't filled in your profile, so do not know which car you have but look here for spares / replacements
Thanks for all the replies.
Yes best to do both sides at the same time, especially looking at the corrosion.
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 766 ![]() ![]() ![]() |
Pretty sure someone on here told me the retaining clips are universal and these can be used as well (double check first though)
Some great advice. I will need some clips so I'll keep checking on here to see if there are universal ones (BMW). |
