![]() | Home > Maintenance & Mods (L405) > Condensation in Rear Cluster |
| Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158
Is there liquid water running around inside the lamp? If not, I’ve had varying degrees of condensation, on and off, from new with my 2017 car. I doubt if there’ll be a warranty claim as it’s even mentioned in the handbook as simply being a characteristic that usually clears when the weather changes |
| Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 |
I know it`s not a 405, I have the same problem with mine L322, what I did was take it off the car it has 2 rubber caps which I removed I then put my blow gun from my compressor and blew it through which cleared the moisture replaced the caps and reinstalled worked for me? |
| finchi Member Since: 25 May 2017 Location: Hampshire and Cheshire Posts: 120
Again this is on a L322. My LH side had condensation and liquid water of about a quarter inch depth in the bottom. The RH side being totally clear and dry. I took the LH cluster off and drilled three holes in the bottom. It's now totally clear, no condensation. However, I wouldn't do that if it was under warranty.
| supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3962
Ive just bought an L405 and from what I can see the only thing that needs some attention is condensation in one of the rear lights. It does disappear in cold weather but then leaves a mark. Has anyone successfully fixed it and can the light unit be "rinsed out" to remove the mark like I did with my L322 front lights. Geoff |
https://www.ebay.co.uk/itm/Captain-Tolleys...SwXIdcTDuB
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35871
link doesnt work for me geoff..
Yea I got a bit in my L322 but this new one has a lot. Drying it out in the sunshine as we speak, yep link is rubbish doesn’t work for me either |
| nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690
works for me-
| Boxbrownie Member Since: 19 May 2018 Location: FF gone now....FL2 i6 to play with Posts: 245
I was always getting water/condensation in the LH rear lamp but never the RH so I figured it must be a failure of sorts.
Unit is now free of condensation but there are marks on the inside of the glass. Looks like the next stage is to "inject" some water through one on the three holes in the base (I assume drilled by the previous owner) and see If they will rinse away before finally drying again and the sealing.
I had some old headlamps which had formed a slight “haze” on the reflectors and obviously impossible to clean as a sealed unit, I didn’t fancy trying water inside and drying out as the silvered reflector surface might have been damaged/marked.
