![]() | Home > Technical (L322) > Possible Transmission Fault?? |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1018 ![]() ![]() |
When the torque converter lock-up clutch on the 5HP24 gets worn it causes a vibration which sounds a bit like driving over a cattle grid. The rev counter needle moves around very slightly in sympathy with the noise. On my L322 I found it was worse at a steady 30mph driving up a gentle incline. Does this fit in with your symptoms, or not really?
Tom Heath Member Since: 19 Mar 2017 Location: Telford Posts: 103 ![]() ![]() ![]() |
Thanks Phil. It sort of does - it feels exactly like driving over a cattle grid, but there is very little noise associated with it - it’s more feel than sound! Does anyone have a contact for a reliable reconditioner?
Hmmm. Still doesn’t sound 100% that it is the LUC causing the issue.
Thanks for this Phil. Much appreciated. If I can find it, I’ve got a BLuetooth IBD module which should pick it up from the ECUs .... however it’s not been seen in the garage for a while ... |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
I am no expert on auto boxes but have been told if you get a feeling like driving over a rough patch of road / cattlegrid it could be the lock up clutch in the torque converter slipping. Before shedding out $$$ try a fluid / filter change and add a dose of DrTranny... https://www.ashcroft-transmissions.co.uk/l...-fixx.html 2007 TDV8 VSE
Thanks for the really helpful comments guys. Over the last week, I’ve been more focussed on listening when and how the rumble happens. I’ve noticed there is a load hum when the judder happens. I’ve dropped it into the local Independent RR place this morning . They are checking it over to make sure there is nothing obvious, but planning to do a tranny fluid power flush today. Hopefully this will give a good indication if it’s the torque converter, even if it’s only a semi temporary fix!
Fingers crossed .... no juddering on the test drive by the garage or me afterwards! A full powerflush with new fluids and additives. Hopefully a £300 cheaper fix! 2005 L322 Tonga Green 4.4l BMW Engine with Touchscreen
