Home > Technical (L322) > Question about radar cruise control
Andy
I was just wondering - when I set the cruise control, the car slows when approaching slower moving cars. Do the brake lights come on to warn following drivers that I’m slowing? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #514778 9th May 2019 2:31pm
ACC [adaptive cruise control] normally uses the engine and gears to slow down but it needs sudden de-acceleration then the brakes are used ...
Post #514782 9th May 2019 2:51pm
Andy
I’ve changed mine to the jag profile using the IID tool and it now stops the car completely. I did wonder if I was going to be hit from behind! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #514788 9th May 2019 3:44pm
mjdronfield
As standard I don’t think the brake lights come on, as it’s only easing off the throttle.
I thought it just primed the brakes on the forward alert, so it went full on when you touched the brake pedal....when it was really close anyway.
Might be wrong, need to have another read.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #514797 9th May 2019 5:26pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
It really does brake for you MJD !
Stan is correct, mostly just uses the engine and gearbox, but if traffic suddenly stops -- or if some dipstick pulls in front of you it will slam the anchors on -- now I don't know if it actually shows the brake lights, but assume it must Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #514803 9th May 2019 7:48pm
mjdronfield
I’ve never had that happen. Don’t use it much though. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #514804 9th May 2019 7:54pm
dolph34
Yes , the brake do come on if the adaptive uses the brakes . Ive seen mine come on at night when the adaptive has slowed the car down with some heavy enough braking Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #514806 9th May 2019 8:13pm
