Home > General > Anyone been to see this one?
Andyschargedse
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
https://rover.ebay.com/rover/0/0/0?mpre=ht...2806884746
As above really anybody been to see it? Is it a lemon thinking of going to look at it as it’s not far from me
Cheers guys
Post #514912 10th May 2019 7:44pm
Andyschargedse
First pic was mot fail then others when it passed today what you guys think?
Looks like it defo needs some wrk. Any advice appreciated
Post #514921 10th May 2019 8:17pm
It sounds like you have the information you need..... they are all items for negotiating the price down
IMHO it seems quite tidy & original from the photos
There's a [url=buyers guide]https://www.fullfatrr.com/forum/post189410.html#189410[/url] in the wiki which should give some additional pointers.
Post #514924 10th May 2019 8:35pm
Andyschargedse
Went to view the car seems tidy an drove well, everything seems to work although the air con didn’t seem ice cold and the
TPS warning light was on check spare tyre, lots of history with it suspension went up and down fine hi and low range, parking break all working as it should. Usual drivers seat wear, a good detail needed ect. Paintwork in very good condition for year apart from the dreaded rust inside the door shut on the rear arch. How much of a job is this to sort any opinions welcome on this one. All headphones and remote with the car for RSE. Another thing to note it’s had an aftermarket rear silencer put on it from cobra that is all cracked and in need of replacement how much do standard boxes go for these days?. Anyway just wondered what your thoughts are guys is there anything I’ve missed/should have checked ect, the car just clicked when I went to start it so a booster was needed they sed it hadn’t been in use so it may just need a good run or a new battery, is there any drain issues on the facelift models. Rear electrics all dry aswell.
Cheers in advance guys for any advice 😊
Post #514985 11th May 2019 5:28pm
Andyschargedse
Just to add it also had a receipt for a gearbox overhaul at 93k car is on 142k now so would prob do a oil and filter change
Post #514991 11th May 2019 6:36pm
TPMS is fragile in that vintage - I bought an IID tool and disabled mine
Battery life is around 5 years, so probably something to replace.
If there's no record of it, then I'd change all the other fluids as well. diffs etc.
Post #514992 11th May 2019 6:46pm
Andyschargedse
Thanks for your reply yes I would change all the trans oils anyway 👍🏼 Any thoughts on the rust?
Post #514994 11th May 2019 7:04pm
Not something I've suffered from.
Plenty of threads to read though ..... here
Post #515021 11th May 2019 9:39pm
