Home > Maintenance & Mods (L322) > Wiring Accessories to the battery question
green-oval-nut
United Kingdom 2005 Range Rover Vogue Td6 Stornoway Grey
Hi, I have a 2002 and 2004 L322. I have added a 150db Lorry horn to one and I am adding spotlights to both. I have fitted wiring kits for these kinds of mods dozens of time to older cars. But after seeing that you have to jump start them without attaching the leads directly to the battery. I am worried about attaching the positive lead of the wiring kit directly to the battery. It has an inline fuse.
Can I just connect it directly to the battery? Or is there another place I need to attach the wire to please?
Thank you.
Post #515365 14th May 2019 11:42pm
wayneg
As I have so many added bits I fitted a 20a self-resetting fuse close to the positive post after which is an Aux fusebox. All my accessories are wired from the Aux fusebox via relays. My trail lights and front light bars are wired onto remote control relays so I can turn them on or off when in or out of the car.
Self resetting fuse under the insulation..
 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #515370 15th May 2019 6:16am
No reason why you can't connect direct to the battery +ve terminal, I have an auxiliary fuse board connected to it for convenience but same difference.
The jump posts provided are more for convenience due to the location of the battery but as far as I know were discontinued on later years models.
Post #515376 15th May 2019 8:53am
green-oval-nut
Thank you. I just wasn’t sure if it was safe until now.
Post #515381 15th May 2019 9:35am
