Home > Maintenance & Mods (L322) > Is my suspension Correct ?
cozzy
England 2015 Range Rover Vogue SE SDV8 Corris Grey
Hi guys , I was wondering if anyone could advise me on my 2011 tdv8 vogue suspension.
My question is this, should all four corners of the vehicle rise at the same rate ? My car seams to do a bit of a seesaw kind of dance !! Shocked Front usually is first up followed by the rear.......it all settles okay in the end (though I'm sure the rear is a little low compared to the front....I have yet to measure the heights).
One job I have not completed yet is a compressor re build , do you think its worthwhile doing this ?
Kind regards,
Cozzy.
Post #515380 15th May 2019 9:34am
wayneg
I have had Classis, P38`s and a L322 all with air suspension, they all do the leveling dance so enjoy the performance 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #515382 15th May 2019 9:39am
gavinn
The see saw dance of front to back is totally normal when raising , with mine the front goes first , followed by the back, has done it since new, when lowering it is more or less all four corners go down at the same time .
Post #515383 15th May 2019 9:40am
Rob99
United Kingdom 2017 Range Rover Autobiography SDV8 Santorini Black
It's normal. I believe it's designed that way to put less strain on the air compressor and not deplete the air tank too quickly. 2017 4.4 SDV8 Autobiography
2012 4.4 TDV8 Westminster - Gone, but not forgotten
Post #515475 15th May 2019 11:14pm
Cavalier
2011 Range Rover Vogue 4.4 V8 Orkney Grey
It's designed to raise the rear first, to stop headlamps (when lit) dazzling on coming traffic.
Post #515664 17th May 2019 9:38pm
@ Cavalier
Well, both my FFRR's must have forgotten that one, front up first then the back, more slowly.
Probably a "road rage" setting I need to change with the iiDTool Twisted Evil .
Post #515670 17th May 2019 11:15pm
finchi
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Mine comes up rear first Very Happy
Post #515679 18th May 2019 8:20am
stu1
Rear first here also - the idea is the front lamps don't dazzle when rising (as mentioned by Cavalier).
Post #515714 18th May 2019 12:55pm
