Home > Technical (L322) > HDC Fault
Videoman1959
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
HDC Fault
Hi Everybody!
So! If I'm driving around town everything appears to be ok. Short journeys, 5 mins, under 40 mph etc..all runs perfectly. But if I go on a journey of 15 mins at over 40mph I get a Bing-Bong warning come up... 'HDC Fault'.. 'Systems Suspended'. Then after a few seconds I get 'Suspension Lowered' with the DSC warning light lighting up and also the handbrake & brake system warning light coming on. Now if I stop the car and turn off the ignition.... and then start it up again, both warning lights disappear until between 6-10 mins later when the same thing occurs. The car drives perfectly with all the warnings lights lit up etc.
Thank you in advance. 'Knowledge Is Power'
Post #515520 16th May 2019 2:35pm
common problem..
here's a few threads relating to this,
https://www.fullfatrr.com/forum/search.php...rch_time=0
Post #515523 16th May 2019 3:53pm
