Home > Technical (L322) > Wobble wobble!
Andyschargedse
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Wobble wobble!
Went to view a 56 plate facelift interior 4.2 supercharged today which seemed to drive fine apart from a steering wheel wobble/ vibration under braking. apart from discs what else could be the cause?
Cheers 👍🏼
Post #516685 27th May 2019 5:42pm
supershuttle
My 5.0LS/C had a wobble under gentle braking, replaced discs and pads up front and that fixed it. I spent a bit of time checking it wasn't anything else. Geoff
Post #516698 27th May 2019 7:33pm
Andyschargedse
Cheers for you reply I was going to check suspension components ect before or I thought it could be a calliper at fault maybe
Post #516702 27th May 2019 7:57pm
kbald
Could be a sticking caliper which is pretty common, warped discs or some bushes have gone soft. Current 2007 TDV8 Vogue Buckingham Blue
Post #516722 27th May 2019 9:28pm
Andyschargedse
👍🏼 All things to check
Post #516724 27th May 2019 10:11pm
