![]() | Home > Maintenance & Mods (L322) > Rear door glass removal ? Any suggestions.. |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826
Download Rave from the WIKI, it tells you exactly how to do it... |
| StewD Member Since: 22 Apr 2016 Location: Glasgow Posts: 129
Excellent thanks for that.. |
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3285
Don't bother trying to re-coil the wire. get a second hand Regulator from a Breaker (c.£30) and replace. You will have to take the whole door card out and the quarter light in the Door frame to get the glass out IOT replace the regulator. |
So... Finally got round to getting Rave and checking out the details of window removal.... |
Stew, it is absolutely a driveway job. I am no mechanic but followed RAVE and managed to take the window out, replace the regulator and install everything to working state. You can do it if I can!! |
Excellent thanks for the response.... Rave shows the quarter light getting cut out and resealed afterwards... This put me off. I take it that's not going to be a required step and removing the channel/runner between the main glass and the quarter light provides enough space to get the glass out ? Current: Supercharged 06 FFRR in Java Black
| p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1587
I recently stripped a door for the glass, winder, and lock, etc. with a view to throwing the door out. Yes, removal of the quarter glass is a cutting exercise.
So job done.... 2nd hand regulator obtained via eBay £29... Less than hour all in. The rear quarter does not need to come out. The trim between the 2 pieces of glass frees the seal enough for the main glass to lift straight out....
| Hornbycrow Member Since: 03 Mar 2017 Location: Blackpool Posts: 2
L322 window replacement. Done
| Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 232
The Video posted is great but as per the note earlier in the thread you do not need to take the seal all the way out as per ty video shows just removing the trim between the two bits of glass and tweaking the seal a bit gives you enough room to remove the large pain of glass. |
