![]() | Home > Range Rover P38 > onboard computer mpg question |
| Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 714
Are you sure you 're not using petrol during start up before it switches to lpg? Paul,
| j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 389
I'm positive it's using petrol initially, but the OBC seems to calculate "correctly" even when reset on LPG during journey. __
| Benfelrr Member Since: 27 May 2012 Location: Wiltshire Posts: 301
I asked a mate who knows more about this generation of Range Rover than anyone else I know and he says...."Mpg... It work out distances traveled from odometer and then calculates fuel consumption from the engine ECU - I think from memory it counts the injector pulses so it knows how much fuel it's used, and then this with the distance traveled is used to get the calculations."
