![]() | Home > Maintenance & Mods (L322) > Question about rear subframes... |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4347 ![]() ![]() ![]() |
Get underneath it and take a look. Might just need a good rub down and waxoyl... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
They can get pretty scalely, get under your ff armed with a torch, safety glasses a screw driver and wire brush, you will know soon enough if it’s just scale or there are holes!! |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2591 ![]() ![]() ![]() |
Thanks Chaps, will have a look |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8775 ![]() ![]() ![]() |
Erm, tow bar doesn’t bolt to the rear subframe. Bolts to the bumper location and the bottom of the monocoque! There is nothing that can't be fixed with a hammer😜😜
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6426 ![]() ![]() |
Check the toe arm inner mounts, these can go south over time. Had to have one on my 02 TD6 welded. .
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3875 ![]() ![]() ![]() |
Nice colour picture for you.
Thanks, does that mean he is talking ![]() ![]() |
