Home > Technical (L322) > Misfire on 5.0 s/c
Skeletor
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Java Black
Misfire on 5.0 s/c
Got a bit of an issues with my 09 5.0 s/c, light acceleration at around 1400-2000 revs getting a misfire, hard acceleration or just nursing it past this rev range seems to be ok, had it plugged in and got
P010B Air flow sensor B
P0420 catalyst system malfunction bank 1.
Tried a brand new air flow meter in bank B ( looking at the engine on the right) but still no difference. Anyone shed any light on these issues?
Post #517836 8th Jun 2019 8:35pm
Piet
Netherlands 2008 Range Rover Autobiography 4.2 SC V8 Lucerne Green
Did you changed the right side? From the WM.......
Cylinder arrangement
Specification
4.2 litre, 90 degree 'V', supercharged, petrol engine, twin overhead camshaft per cylinder head, 4 valves per cylinder
V8, numbers 1 and 5 cylinders at front of engine when engine is viewed from rear
Number 1 cylinder - right hand bank; Number 5 cylinder - left hand bank
Post #517886 9th Jun 2019 2:41pm
Skeletor
You could well be right I was going off this I had off another member:
Post #517891 9th Jun 2019 3:07pm
Piet
Hope, if you switch the sensor, it wil work.
Good luck.
Post #517892 9th Jun 2019 3:20pm
Piet
Also, check for a airleak in, somewere along the air intake.
Hope you do find something.
Piet
Post #517943 10th Jun 2019 11:07am
Piet
Any luck on this Sir?
Post #518236 12th Jun 2019 8:37pm
Skeletor
Tried another new sensor in the other side and I think it’s sorted now. Difficult to tell 100% as it didn’t do it all the time
Post #518253 12th Jun 2019 9:46pm
Piet
Good job, hope it works and stays that way.
Fingers crossed
Post #518392 13th Jun 2019 9:11pm
Skeletor
Took the car for a good drive over the weekend, still has same issue. Would ‘P0420 catalyst efficiency’ give this sort of misfire / hesitation?
Post #518808 17th Jun 2019 7:59pm
Piet
I dont know Sir, but Ill think best is to begin with any leaks in the inletsystem
( lean running ) en/or faulty oxygen sensors.
Post #518924 18th Jun 2019 5:54pm
