Home > Technical (L322) > Hooray - new car finally! |
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 220 |
Yes Bluetooth is standard on a 2007 car, do you see phone not fitted on the head unit if so try and pair with something on your phone and pick Land Rover with the pin 2121.
10th Jun 2019 6:55am |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2180 |
Hi there it’s not showing up for pairing anywhere in the center console there is a phone dock - I suppose next check is the unit in the boot then! Cheers Current stable:
10th Jun 2019 7:59am |
Had a quick look on the boot it’s dry as a bone I took a picture of the modules which is bt? Or is it missing? The very top one says Nokia
10th Jun 2019 9:43am |
Gyre8 Member Since: 14 May 2017 Location: Wolverhampton Posts: 252 |
Does your phone find 'Landrover' when pairing from the phone BT menu (not the Console)?
10th Jun 2019 9:48am |
Unnecessary quote removed
10th Jun 2019 9:50am |
Here's a quick pic of my working setup:
10th Jun 2019 10:02am |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1097 |
Looks like the MOST cables are missing from your unit Dan -- the end of the box closest to you! Current: 2011 FFRR Vogue SE 4.4 TDV8
10th Jun 2019 10:45am |
The top box that says Nokia does have a plug missing so I should try finding that first? Any advise on my other points? Cheers Current stable:
10th Jun 2019 12:18pm |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 498 |
Nice looking car Dan
10th Jun 2019 1:50pm |
Dan see the white fibre's in Gyre8's piccy ^^^ where are yours? -- probably joined together, which probably means the Bluetooth unit is FUBAR and been 'wired out' of the loop Look up bic pen fix on here to see what folk do Current: 2011 FFRR Vogue SE 4.4 TDV8 Previous: - 2004 FFRR Vogue 4.4 V8 with LPG 1997 P38 4.0 SE with LPG 1997 P38 4.6 Vogue with LPG |
10th Jun 2019 2:05pm |
Regarding the disco flashing indicators, you are correct it does need a resistor added to cheat the system.
10th Jun 2019 2:13pm |
Thanks guys yes I see what’s missing now will have a look later at this Current stable:
10th Jun 2019 2:42pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3193 |
Looks as if the Nokia unit has gone defective and been bypassed. Replacements readily available.
10th Jun 2019 4:41pm |
4.2 s/c
10th Jun 2019 5:37pm |
