Home > Technical (L322) > L322,TD6,Key Removed Engine still Running. |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 816 |
I heard of this on a P38 diesel. A farmer friend had one and had to carry around a container of water to throw onto the diesel pump. I watched him do it one day when he turned the ignition off and the engine was still running, he walked calmly as anything around the front, opened the bonnet and poured water on the pump, sure enough the engine stopped.
12th Jun 2019 11:24am |
Fraynizzle Member Since: 27 Apr 2015 Location: Essex Posts: 111 |
sounds like diesel runaway - lots of stuff online about it and some interesting videos on youtube.
12th Jun 2019 1:18pm |
daveturbo Member Since: 11 Nov 2012 Location: county durham Posts: 102 |
IT WILL REV UP PERFECTLY,ALL THE ELECTRICS WORK AS THEY SHOULD,SO I THINK ITS AN ELECTRICAL FAULT,TO HONEST. Mercedes AMG w207
12th Jun 2019 2:36pm |
how long does it run on for? |
12th Jun 2019 3:09pm |
I think it is an electrical fault as well. You haven't fitted any relays or led lights lately by any chance? |
12th Jun 2019 3:17pm |
Some times i have to disconnect the battery earth lead and turn on everything electrical and can still take 2 minutes or so,other times it will just stop itself if everything electrical is on. Mercedes AMG w207
12th Jun 2019 3:57pm |
if you disconnect the battery and it continues to run im not sure how it can be an electrical issue? the engine is getting fuel or oil or both after key off allowing it to run. if you have disconnected the battery it can only be from worn components nothing is actively electronically operating? |
12th Jun 2019 4:06pm |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 843 |
The only way to switch a diesel off is by removing the fuel source. When you turn the car off what you are actually doing is isolating the fuel supply. This is why a diesel doesn’t have spark plugs as the diesel ignites when compressed and will just keep running regardless of the battery being disconnected.
12th Jun 2019 5:25pm |
if the fuel pump relay is stuck closed so powering the fuel pump even after ignition is off, that is the low pressure end. the injectors are all electronically controlled so how is the low pressure fuel getting into the cylinders after key off with the injectors all closed...? |
14th Jun 2019 2:23pm |
did you get anywhere with this Dave? |
20th Jun 2019 3:52pm |
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 218 |
Bit late to the party with this but years ago had some thing like this with my first classic, fitted extra earth leads between engine and body and body to battery cured it. |
22nd Jun 2019 9:45pm |
