![]() | Home > In Car Electronics (L322) > Denso nav firmware update |
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1100 ![]() ![]() ![]() |
Yup, it's only the 2009/2012 that can't Current: 2011 FFRR Vogue SE 4.4 TDV8
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35832 ![]() ![]() |
what year do you have now Dan?? [update car profile??]
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2251 ![]() ![]() ![]() |
Hi Stan good point it’s and 07 - is there a firmware update as well as map updates though? Current stable:
Piet Member Since: 22 Mar 2017 Location: Maasdam Posts: 199 ![]() ![]() ![]() |
Ill think not |
I believe there is, I'll do some digging for you Dan Current: 2011 FFRR Vogue SE 4.4 TDV8
Thanks bushy! Current stable:
,did you have any joy? Current stable:
Sorry Dan, yes -- Map update discs often come with the firmware update which is applied before the map update is applied - I can't be sure if this is the case for all iterations of Map update but certainly most Current: 2011 FFRR Vogue SE 4.4 TDV8
