![]() | Home > Maintenance & Mods (L322) > New car water ingress help |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2246 ![]() ![]() ![]() |
Ok update on this the rear driver side of the boot the headlong is wet and dripping near the rear fuse box - any ideas? As a temp fix when the rain stops I was going to try duct taping the gps unit? Current stable:
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198 ![]() ![]() ![]() |
Dan
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299 ![]() ![]() ![]() |
Also water gets in through the sat nav aerial on top of the car I had a leak here I ran a bead of silicone around the base of the sat nav aerial easy fix. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Jaysta I have put duct tape on for now but will do your trick next
Right update after today’s downpour
Ok as its dry now I tried to clear all my sunroof drains 3 wer blocked! 2 driver one passenger. Passenger front and back are now flowing well driver rear also the same BUT. The driver a front one I've tried striker cable brake cable etc and I can't get more than 8 inches down I can't blow it clear its so built up and I can't get in underneath as the compressor cylinder is bang in the way... Any advise please ? Current stable:
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 508 ![]() ![]() ![]() |
Dan,
Morning got up early (in a rage about this) had a look it’s not touching and as I have deployable it looked like a massive ball ache before work - so had an idea rather using are to blow it clear (which I understand is a no no) I got the dyson out and fashioned a pipe to it with gaffa tape and I manage to suck enough crap out to then be able to blow it clear and out a couple of kettles of water down. Result! Current stable:
Hi all,
Hi all still need some with this after this weeks heavy rain I have a bit of an update - double checked drains all good - but there was a very wet spot about the middle of the rear passenger door - right on the edge by the door it was soaked... any ideas what is hear to cause it it was so wet it was brown.. also took the sub out to fix it and it was wet there it looks like runs down that pillar into there..? Current stable:
