Home > Technical (L322) > 2005 L322 td6 - Immobiliser? |
gj88 Member Since: 10 Sep 2018 Location: West Midlands Posts: 213 |
Why not check the fuel pump first, it's two bolts under the passenger side rear. Turn the key to II and get under to see if it's running, should be fairly obvious. Easy to rule out and the work of about 2 minutes. |
15th Jun 2019 7:16pm |
jeh1971 Member Since: 15 Jun 2019 Location: Stockport Posts: 5 |
I hear you, but if the vehicle is immobilised surely Iām wasting my time? |
15th Jun 2019 7:52pm |
I'd thought at position II everything came on as normal with an immobiliser issue, but then wouldn't turn over, but I could quite easily be talking rubbish, I'm sure someone will be able to confirm. Obviously if the pump won't run in II you would be wasting your time, but if lights etc are coming on, it may be worth a couple of minutes to check |
15th Jun 2019 8:06pm |
I agree, well worth checking.
16th Jun 2019 11:47am |
Afraid not mate, hopefully someone else can help on the immobiliser issue.
16th Jun 2019 2:00pm |
Just had the cover off the remote fuel pump, gave it a whack, engine started first pop. Never thought that agricultural diesel would sound like music to my ears!
22nd Jun 2019 11:45am |
Glad it was something easy. I limped mine on for a few months by just carrying a rubber mallet in my boot and giving it a whack when it played up. Really shouldn't have bothered as it was such an easy swap |
23rd Jun 2019 3:36pm |
SteveMFr Site Sponsor Member Since: 22 Nov 2009 Location: Strasbourg, France Posts: 1641 |
Nice to hear it was an easy fix.
23rd Jun 2019 5:08pm |
What the hell's with those stupid hose clips?? Unfortunately my eyesight is such that they're too close to my face for me to be able to see how they work... |
29th Jun 2019 3:08pm |
WightinNL Member Since: 15 Jan 2020 Location: Isle of Wight Posts: 1 |
Glad you sorted it - thought it was going to be similar to an issue I had a little while back, as your opening scenario is the same - Ill continue anyway for benefit of others. Possibly I caused my issue by disconnecting the battery too quickly after turning ignition off...
15th Jan 2020 5:09pm |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 843 |
Another happy customer! š |
15th Jan 2020 5:40pm |
