![]() | Home > Technical (L322) > Headlight woes - halogen main beams on when they shouldn't |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
fill your car profile in so we know what year/model you have .. ... - .- -.
ArtFF Member Since: 18 Jun 2019 Location: NI Posts: 8 ![]() ![]() ![]() |
It's all there, not sure why it's not appearing
select the colour |
D’oh apologies... fixed |
Doing some more reading I'm 99% sure it's the indicator stalk.
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 ![]() ![]() |
Not done it myself but had the steering wheel cowling off a few times for the reach motor. The leather gaitor clips off and sides back and underneath the steering column is 3 or 4 torx bolts holding the plastic cowls together. I seem to remember there are 2 different sizes - T25 & T27 needed (don't quote me) and you'll need these to be long handled as they are quite deep and a normal screwdriver length won't reach. You should then be able to see the indicator stalk and switch it out. I suspect someone else will be along if there is any special needed to remove the actual stalk Current Fleet:-
Brilliant thanks Nick. I had a look underneath and saw the holes for the screws. I have torx bits, lets just hope my socket extension is long enough. Replacement stalk here tomorrow hopefully. |
Update... plugged in the new stalk, same problems. Either LCM or wiring has gone wonky I guess |
Found an LCM from the same year on ebay for buttons so figured worth a try.
